I am looking for a way to set MCodeActions using KMotion_DotNet. I found an old post indicating that this functionality is not yet included in KMotion_DotNet. So If I want, for instance, to set up an M-code to run an on-board C-program in a given thread, then it appears I will need to launch some native code to do the setup. Is that correct?
Any idea when MCodeActions will be exposed in the DotNet interface?
